RCU Forums - View Single Post - the hyper st PRO thread!
Old 08-29-2007 | 11:08 PM
wrat's Avatar
wrat
Default RE: the hyper st PRO thread!
ORIGINAL: pballdale
Need some help with my hyper! I am rebuilding the centre diff ( to put oil in ) from my new kit, and two of the screws have been rounded out, ffs stupid red loctite [:@] Does anyone have tips on how i could remove these screws! I need help I have got some spare screws for, but before i drill out these screws is there any less barbaric way of doing it?
thnx,
ps: i have the uk spider diff version :P
i take it its the screws under the chassis that go into your diff holder....i would use a dremil with a small disc and cut a straight line so you can use a flat head screwdriver..if you have access to a small hobby blow torch then heat the screw up from underneath..be realy careful..your not trying to burn the thing just heat it up slowly..that should losen the glue..dont burn yaself..or drill the head of the screw off ,so you can pull it thru..
hope this helps
