RE: new to the club
Well UPDATE!!
I started the engine today, found out one thing, THE MIXTURE is set to wereever the factory is, and i'm at 1600 ft asl, the engine would idel but as i advance the throttle the engine would die, i had to remove the mixture limiter as i need to lean the engine way down. Ran a tank throught the engine going from rich to lean, after the tank was done, My Nexstar was dripping with fuel along the right side..
Justin
