Which hole to use on control surface horns
Trying to set up proper control surface travel on my Multiplex Easy glider, and having problems. Question is this: Can someone explain to me which holes on the servo arm and which holes on the control surface horn are used to get the longes travel and shortest travel. Basically not sure which holes to install the pushrods in. Thanks Nikolai
