ORIGINAL: CHV69
Keep moving the CG forward.
I have my CG on both Integrals at 165 mm back from the leading edge at the root. I need down elevator to hold level inverted and on 45 degree up lines. Mine pulls very slightly towards the canopy on up lines upright and quite a bit to the canopy on down lines.
I added a mix for the down lines. I did not mix for the up lines.
Carl
That sounds like a good approach. Did you end up flying with a bunch of uptrim then?
Jim
