Overheating?
The way I remove a stubborn flywheel is by backing off the clutch nut about 1 full turn, rest the end of the pilot shaft (or clutch nut) against a piece of scrap wood and gently tap the back of the flywheel with a hammer. You shouldn't need to use much force.
