ORIGINAL: Redback
Smo0,
Can you explain a bit more as to what happened when you seemed to lose communication. How brief was the break, I assume that it was long enough for you to put some control inputs in that did not seem to get responded to.
As Alan said, the Spektrum come with quite generous batteries, both Tx and Rx.
BTW Alan, glad yours works OK, just about to put one into my Precision Aerobatics 30% Edge 540.
Regards
Terry
G'day Terry,
I think you will need 2 batteries in the Edge, I use 2 in my Katana, I have a 1700Mah, & a 1100Mah battery, use 2 switches & 2 charge leads, much better security, & redundency. See Pic.
As long as the 2 batteries are the same number of cells, & of course voltage, it does not matter if the capacity is different.
Are you going to Warialda in November, I will be there, it's for a good cause, lots of fun & only a short trip for you, from Grafton.
Hope to see you there.
I'm off to put the Katana on charge, ready for tomorrow, (Sunday).
