RCU Forums - View Single Post - OS 52FS has lost compression
Old 09-01-2007 | 06:00 AM
DarZeelon's Avatar
DarZeelon
Default RE: OS 52FS has lost compression
Don,
50 flights is only a bit over 10 hours.
This is not sufficient time for your engine to have worn-out, i.e. to need a new ring.
With a four-stroke engine, even if you try running it lean, it will stop and possibly even back-fire and throw the prop.
Do check the valve-lash, like Dave wrote. This must be done with the cam-follower on the base-circle, i.e. at zero lift.
As a rule, compression is always checked only with the throttle wide-open, as Jim wrote.
