OS 52FS has lost compression
Old 08-31-2007 | 08:45 PM
twinster2's Avatar
My Feedback: (57)
Default OS 52FS has lost compression
I have a OS 52 four stroke that has very little compression and refuses to start. The engine use to start easily, but has sat around for about 1 month without used and now it feels like there is no compression. I have added fuel to the cylinder but is still does not seem to have any copression. Any ideas. The engine has about 50 flights on it.
Don
Old 08-31-2007 | 08:48 PM
w8ye's Avatar
My Feedback: (16)
Default RE: OS 52FS has lost compression
Open the throttle wide open and see if it has compression?
Old 09-01-2007 | 12:56 AM
Flyboy Dave's Avatar
My Feedback: (21)
....check your valve clearances....see if one of them has closed up. If that happens
you wont have any compression.
FBD.
Old 09-01-2007 | 06:00 AM
DarZeelon's Avatar
Don,
50 flights is only a bit over 10 hours.
This is not sufficient time for your engine to have worn-out, i.e. to need a new ring.
With a four-stroke engine, even if you try running it lean, it will stop and possibly even back-fire and throw the prop.
Do check the valve-lash, like Dave wrote. This must be done with the cam-follower on the base-circle, i.e. at zero lift.
As a rule, compression is always checked only with the throttle wide-open, as Jim wrote.
