RCU Forums - View Single Post - Pentathlon Kit Build
Old 09-02-2007 | 12:16 AM
flyintexan's Avatar
flyintexan
Default RE: Pentathlon Kit Build
I normally start by sheeting the foam parts. Although this is a bit of a long task, once completed, the rest of build can move quickly (relatively) .
Those that purchase the kit with all of the 1/16" sheeting will need to inpsect the sheeting and begin truing the edges of these sheets. I normally use a long straight edge and a sharp razor. You can also setup a straight edge sanding jig to do the job.
ID:	754896   Click image for larger version
ID:	754897   Click image for larger version
