RE: Which hole to use on control surface horns
Hi!
There is some basic rules you must follow when you instal the controll linkage. Those are:
Always strive to have as short servo arm as possible and always strive to use as long controll arm as possible. This should be written in stone!!!
Why ? Becuse then you will have a stiff set up!! Which is very important in an airplane.
