RCU Forums - View Single Post - Pentathlon Kit Build
Old 09-02-2007 | 04:13 PM
flyintexan's Avatar
flyintexan
Default RE: Pentathlon Kit Build
The rudder and vertical fin can now be marked to cut the hinge lines and fusebox cutout. There is a dimensioned drawing in the build CD that shows the locations for these lines. I tape the marked fin back into the shuck and then run it through my hobby band saw. These surfaces can be lightly block sanded and capped with the 3/8" balsa pieces.
A note about the trailing edge of the vertical fin: This piece extends down well below the vertical fin and will mate with the end of the fusebox. Take a moment to make sure the alignment of this piece is correct so that it will mate up with the fusebox properly at a later time.
ID:	755339   Click image for larger version
ID:	755340   Click image for larger version
ID:	755341   Click image for larger version
ID:	755342   Click image for larger version
