RE: Composite-ARF Integral, kinda build thread
Colin,
If you look inside the stab, there will be a glob of white epoxy glue on the carbon tube. On mine it's 91.5mm from the root. Drill there and run your screw through to the epoxy. You can also wedge a piece of ply in that area and epoxy it in so you don't have to recess the hole for the screw.
Jason
