RCU Forums - View Single Post - Genesis LE 500k diff oil problem
Old 09-03-2007 | 09:43 AM
derrick05
Default RE: Genesis LE 500k diff oil problem
Sort of ran into the same thing with my NEMESIS.I had to much diff fluid packed in there,had to go back and take a little out.Check to make sure your brakes are working properly.I thought I had drivetrain trouble at one time,but for some reason my rear brakes were grabbing,even with the brake post in the neutral position.I took my entire NEMESIS apart and put it back together and have had no issues ever since.Does anyony know if it is okay to run only rear brakes?Been thinking of removing the front set,just not sure if thats okay with an unlocked center diff.
