RCU Forums - View Single Post - Genesis LE 500k diff oil problem
Old 09-03-2007 | 12:27 PM
Hot Head6
Default RE: Genesis LE 500k diff oil problem
I played with a little this moring checked to see that the drivetrain and brakes were free and they were.So I ran it to warm it up and it was running rich about 196 temp which is weird because before I added the oil it was running great I thought about 230 to 240 deg and it screaming(I thought).I started leaning it out and oh my this this really screams got it running about 225 degs and if I stay in the throttle it will flip over now.Is this temp go or can I lean it out some more?I just changed the center diff oil now what should I put in the front and rear diffs?now I have to do the check valve mod can I use a check vavle or should I use the ofna primer bulb check valve?I want to thank you guys for all the help!And TRD you are the man it just need tuning like you said hard to believe the way it was running before thanks alot
