RCU Forums - View Single Post - Jetcat software question
Old 03-18-2003 | 04:45 PM
purge98
Default Jetcat software question
I currently have a P120 (bought New in the UK) with an ECU type 4.9 and running GSU version 4.00 L software.
After sucessfully setting up the radio I have noticed two things:
1) The EGT is showing (with the turbine cold) around 50 deg c even though the ambient tempertaure is 23 deg c.
2) I cannot seem to put the turbine in Manual mode by pressing the Manual GSU button/ or led unit button. The turbine bleeps once but the amber led does not light.
3) It also says in the manual (page 32/51) that the Temp. value units in the run menu can be selected in the Limits menu. There is no selection of this kind in this menu.
I wonder if you could shed some lihght on these three problems for me.
Many thanks
