RCU Forums - View Single Post - How does the Y harness with reverse work
Old 09-04-2007 | 07:18 PM
bruce88123
Default RE: How does the Y harness with reverse work
ORIGINAL: DerekChurch12
I am finishing up on my first attempt at building a P-51. The problem is this. My receiver has only one imput for the aileron so I had to use a Y harness with a reverse function. I have messed around with it some but found that the ajuster will move the servo but it wont return back to its position. Does anyone know how this works? I am using it with a JR transmitter and receiver. Thanks in advance for any help.
Derek C.
First, Receivers have outputs not inputs. The input is called an antenna.
I guess you mean the adjuster in the reverser moves the center on the related servo but what do you mean it won't return to its position? What position?
Did you buy a reverser for a JR?
http://www2.towerhobbies.com/cgi-bin...&I=LXAFN2&P=ML
A Futaba reverser will not work.
