RCU Forums - View Single Post - beginner learns how to jump
Old 09-05-2007 | 08:39 AM
Oliver_Klozov
Default RE: beginner learns how to jump
The all jump the same when it comes to throttle you should also let off the throttle when your car is in the air so you don't chew spur gears from over reving or landing with the spur flying...But yes if you hit the gas in the air your front end will come up and if you let off it will drop down.
