beginner learns how to jump
CA
I finally bought myself a used xxxnt. I am used to running 1/8 buggy and truggy. My question is that, since ST is only 2WD...when I jump, do I need to jump it differently. 1/8 needs to have some mid air throttle control to dip or raise the front? Can you teach me how to jump a ST? Thanks.
The all jump the same when it comes to throttle you should also let off the throttle when your car is in the air so you don't chew spur gears from over reving or landing with the spur flying...But yes if you hit the gas in the air your front end will come up and if you let off it will drop down.
