If you go with the black props, be sure to put some sort of paint on at least one tip so you will see the prop arc when the engine is running. If not, you may discover that rigid plastic props and fingers don't mix too well. You could end up with a small (or large) skin transplant. I speak from experience. Good luck, Dzl
