choice of prop for 46FX on a Trainer >
Old 03-18-2003 | 11:18 PM
Default choice of prop for 46FX on a Trainer
Guys, whe I did a search for "best" prop, most threads were for sport planes/3D. How about a reasonable prop for the OS 46 FX on my Hobbico Superstar Trainer? 11x6, 10.5 x 6 (I'm hoping for the 10.5 diameter--more ground clearance to avoid prop strikes on the ground)
Thanks!
Old 03-18-2003 | 11:29 PM
Go with the 11x6
The black nylon props from Master Airscrew are a good choice, almost unbreakable.
Old 03-18-2003 | 11:36 PM
I am using an 11X6 on a 46FX mounted in a 1/6 scale Cub. I have a friend who uses a 10X6 on his 46FX, but I can't personally vouch for that setup.
I have to disagree about using a Master Airscrew. For my money, I'd go with an APC.
Old 03-19-2003 | 12:20 AM
Im with stick Jammer,
For a trainer those black Nylon props are great. You dont really have to worry about breaking your prop and can just concentrate on soloing. Ive had mine for about 4 months and its still looks great. There cheap and you only need about one or two for your entire trainer period.
When you can land without chipping your props then go with more advanced props (wood, APC).
Papa
Old 03-19-2003 | 02:15 AM
Stick Jammer, Crotts, Papa---Thanks for you opinions---I'll go with the 11 x 6 MAS (no APC props until my landings are more consistent)
Old 03-19-2003 | 02:30 AM
twostroke's Avatar
I can never get APC props to fit in my spinners an so I use the master's and have good luck with them
Old 03-19-2003 | 02:34 AM
P-51B's Avatar
APC 10x6 to start. Then APC 11x5 when you want some areobatic thrills.
Paul, if you are worried about prop clearance it will not hurt to go with a 10 x 6. If an 11" will work go for a 11 x 5. You don't need speed on a trainer.
Ed M.
Old 03-19-2003 | 03:22 AM
If you go with the black props, be sure to put some sort of paint on at least one tip so you will see the prop arc when the engine is running. If not, you may discover that rigid plastic props and fingers don't mix too well. You could end up with a small (or large) skin transplant. I speak from experience. Good luck, Dzl
Old 03-19-2003 | 03:47 AM
Default 2cts
Greetings,
I started with a 10X7 on my LT-40 with an FX .46.
I switched to 11X5. You get less speed but more thrust. Makes it much easier to land the LT-40 (which likes to float alot).
Old 03-19-2003 | 10:01 PM
Hey crotts,
Just curious, how many of your APC props have survived an encounter with the ground? I,ve never seen one that has.
Old 03-19-2003 | 10:23 PM
I like 11x5's on most .46 engines.....I use APC's, but I would probably use a Master Airscrew on a trainer, because they do hold up really well......I don't know if Master Airscrew makes this size however.......might have to go with the 11x6.
Old 03-20-2003 | 01:42 AM
Thrust is what i'm looking for, not speed. Basically, I'm looking for the 46 FX to get me off the ground quicker. I'll look for the 11 x5.
