RCU Forums - View Single Post - Composite Qns - Pattern Planes
Old 03-01-2002 | 04:27 AM
can773's Avatar
can773
Default Composite Qns - Pattern Planes
As promised pics of what is going on
This one is showing an aluminum fitting that we made to support the plate. The part of the fitting that is in the plate takes up the compression loading from the bolt, and the larger diameter that sits outside takes up the thrust load and the torque loading on the glue in shear (minimal). These can be made of a peice of dowel and a ply disk, the bolt runs all the way through the fitting.
