RCU Forums - View Single Post - De-Annodize? Possible?
Old 03-19-2003 | 06:57 PM
Celly013
Default Re: works everytime
Originally posted by kolorkraft
use drano crystals in cold water let soak for about 10 minutes and that nasty stuff is gone. then you can polish to a high shine. i rinse them off with water and scrub a little to get the black crud off with a 3m scotch brite pad then polish and looks awsome. easiest method i ever used being everthing i put together that is the first thing thatcomes off the nasty coloring of anodize i personally like the metal lokk!!!!!!!!!
good luck
steve
... Hey ... I Know you ...
You better not spend too much time over here, or the HPI guys might loose their cool...
