RCU Forums - View Single Post - Free parts from CEN
Old 09-06-2007 | 08:55 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: Free parts from CEN
Your going to see 2 gaskets. They are there for proper spacing and compression adjustment. I am not surprised to see the misalignment of the second gasket. When a manufacturer assembles thousands of units there will be 1 or 2 that might get by QC. Now if you call CEN they will be very happy to replace ANY parts that have been damaged on that Engine. Just give customer service a call and they will hook ya up. you should use the second gasket as the compression will be a touch higher and cause possible unneccessary damage to the unit...
Call them: 714-792-1924
Exactly as Soilwork said,, Check it out before you break it out!!!
I always take apart new engines of all brands to clean out any possible debris that may got in there while manufacturing, it happens in factories...
