RCU Forums - View Single Post - Threading a brass shaft
Old 09-08-2007 | 02:14 PM
hansvonpensch
Default RE: Threading a brass shaft
Thank you patman, lows had a set for $20 with no handel. home depot for $45, and nither place sells the handel seperate, I found a new looking single 10-32 die at the flee market for $1 so know I just need a handle. I plan on trying some how using a 90 degree drafting to help me with the squareness. When I find a handel I will keep you posted on the outcome.
The whole reason for this is the ss shafts are not as straight as the brass ones and the make a raquet when the shaft is spinning.
