RE: saito 82 fuel
Good to hear. So while your waiting on the prop do a few things to get the engine ready. Pull the valve covers and check the clearance. While the covers are off run some light oil or after run oil down the push rod tubes. You should also put a piece of fuel line on the crankcase vent and put a little oil in there. Now check every bolt on the engine with your tool kit. Then stick it in a zip-loc and when the prop comes you will be ready.
David
