RCU Forums - View Single Post - Tamiya MF01
Thread: Tamiya MF01
Old 09-09-2007 | 01:41 PM
pcomm1
Default RE: Tamiya MF01
ORIGINAL: dima5
Hi,
1 - Does anybody know what the cn1, cn2, and cn5 connections are for on the MF01 unit?
2 - Would it be possible to use a 6v 13a battery to run the drive motors using the T03 and MF01 units?
3 - If not would it be possible to connect "Y" cables to the receiver and split the control signal
between the T03 and separate ESC's?
cn1 = Tamiya Battle Unit
cn2 = LED Emitter
cn5 = unused ???
Would it be possible to use a 6v 13a battery to run the drive motors using the T03 and MF01 units? No, 7.2V or your risk damage.
If not would it be possible to connect "Y" cables to the receiver and split the control signal between the T03 and separate ESC's? Yes, works good, you will sync the sound to the function.
