RCU Forums - View Single Post - How to convert an ATX power supply to rc use
Old 09-09-2007 | 11:03 PM
mrasmm
Default RE: How to convert an ATX power supply to rc use
sounds like you are good to go to me as long as your charger can run on the power that the PSU puts out. If you are planning on using too many amps you may get an undervolt. Just watch the voltage when you start to put a load on the charger, and make sure that it stays a good amount above the min voltage the charger can operate at =)
