RE: HELP! Nitro .46, what the?
Hey
Put it in a bucket, started it again. Leaned, Richened, Tryed all i can at the moment. When i do get it started, it runs for a little, then dies. Then i try to start it after that, it sounds like it has no fuel, then when i put the starter on it then open the throttle full and i can see bubbles going up the fuel line to the engine. Do you have to bleed the fuel lines on these engines? i just put a new fuel tank in it, i checked the plumbing as well but i couldn't find anything that was leaking. Iv got a spare carb, so i might try to put that on. But its still wired because why would it still run with the starter on if there wasn't enough fuel.
Thanks for your patience
Dave
