RE: Help Me!
Darkfire, you need to set the trim so the throttle closes all the way or the throttle servo linkage no longer has any force on the Carb Slider. Once you have determined that the servo is no longer controlling the slider you will turn the idle screw in until it holds the slider open and holds the desired idle RPM..
