CEN Racing This forum is to discuss all CEN Racing products.
Help Me!
Old 09-12-2007 | 04:37 PM
  #76
CEN Racing's Avatar
Default RE: Help Me!
Darkfire- look into your carburator and if there is no opening in the slide at all , you need to adjust that by turning the idle set screw on the bottom of the carb. if you still cant do it or you dont understand what i am trying to say you can give us a call at 714-792-1923 ext: 100 we will be glad to help you out.
the opening in the carb should be between an 1/8th of an inch and a 1/16th of an inch
Old 09-12-2007 | 04:43 PM
  #77
DarkFire989's Avatar
Is the slider the little rod that moves in and out inside the carb?
Cause I have already turned the idle screw all the way in to open it up. I would like to show pics but my Pc is being annoying.
Old 09-12-2007 | 04:56 PM
  #78
CEN Racing's Avatar
Yes it is. if you have already tried that give us a call and we will try to help you out over the phone. 714-792-1923 ext:100
Old 09-12-2007 | 05:00 PM
  #79
If you take the air filter off and look down into the carb, there is a shiny "barrel" in the opening-- that is the slide. There should be small gap where air can pass through when the engine is idling. The throttle linkage pulls this slide open when you pull the throttle. Having the throttle screw turned all the way in doesn't sound right. Double-check that you are adjusting the idle screw; you can see the slide move as you turn the screw.
Old 09-12-2007 | 05:40 PM
  #80
I know im getting closer to keepin it idle, So your saying that having my idle turned all the way in shouldnt be like that? Ill try to loosen it a bit. Should I try using my ofna check valve?
Old 09-12-2007 | 06:39 PM
  #81
The Real Dogman's Avatar
No the OFNA Checkvalve will not help in this case. You will need to adjust the idel screw which in the front of the carb entering the carb at an angle.
Old 09-12-2007 | 08:32 PM
  #82
So should i not have my idle screw set all the way in?
Old 09-12-2007 | 08:53 PM
  #83
If your idle screw is turned in(Clockwise) all the way to the point where it is tight, then its in too far..
Old 09-12-2007 | 09:07 PM
  #84
ok, how much should i loosen it, well i guess it all depends on how i can get the truck running
Old 09-12-2007 | 09:36 PM
  #85
Well before you losen it look down the carb and see if the Slider is open at all, if its not then there is a problem with the idle screw.. Check that before you do anything..
Old 09-13-2007 | 03:22 PM
  #86
I really dont get what the slider is, is it that piece with the half circle that moves in and out. There is like a 1/16 gap between the top of the circle to the wall of the carb
Old 09-13-2007 | 10:50 PM
  #87
burningpoo's Avatar
Darkfire...i'm back into this from now from close to your age so where almost on the same page but i think i've tryed more crap out...when you take our filter off the hole u look down has a peice that moves when you hit the gas...that's the slider i think everyone is talking about...it has the almost half moon end on it...there should be a little opening at the end of the half moon...when you hit your brakes this should stay open. the little black screw under your HSN on the left down below the HSN. My trucks at home but I think it's to the bottem right of the HSN but the left of the carb when your looking at your truck from the driver side. i think
From what little I know of new nitro rc's this engine is a tough one from the start. She didn't like being new at all. Just past a gallon because fuel is alot right now but she's killer at the end of the first gallon! just take time to learn her. good luck and I wish I could post pics so I hope I helped.
Old 09-18-2007 | 02:42 PM
  #88
Alright guys I have concluded why my truck is not idling correctly. The socket joint on the carburator arm was very loose, almost all the way off the threads, so thats why even with the trucks idle screw all the way in the carburator arm had it shut closed. Now how far is it down our your trucks? A picture would be nice. Pg: 23 in your manual, the part is the carburator arm.
Old 09-18-2007 | 06:42 PM
  #89
CEN Racing's Avatar
hey dark fire your going to wnat to screw that on over half way in fact go about 3/4s of the way but your probably going to want to replace that ball cup cause its probably stripped in the plastic .
Old 09-18-2007 | 07:24 PM
  #90
I actually havent stripped that piece yet. I have it tightend almost all the way down the threads and my idle screw is set at the factory settings. It idles well but when i put on the break it shuts off. Should I increase the idle screw more?
Old 09-18-2007 | 08:01 PM
  #91
Darkfire, yes add some more idle by turning it in clockwise.
Old 09-19-2007 | 02:45 PM
  #92
Alright guys my problems are over!(knock on wood, hehehe)I just turned in the idle screw a bit and it can idle while my finger is on the break. It will require a little tweaking and my car seems to be running a bit rich. But thats not a problem and i took off the head and my piston was nice and silver. I would like to thank you all for helping me: TRD, The guys at CEN, Burningpoo, Eplummer, and more, sorry if i didnt list you, too many people helped me
Old 09-19-2007 | 03:14 PM
  #93
CEN Racing's Avatar
Your welcome for the help dark fire NOW GET TO BASHING YOUR TRUCK AND HAVE FUN Go kill the competition
Old 09-19-2007 | 05:39 PM
  #94
I really need to figure out the balance with the idle and carburator arm. I thought it was fine but it ocasionally cuts out on me while holding the break too long. I'll figure it out eventually. I dont know if this is because of the break in process, but i can see a little smoke comming off the engine after its been running for like 5 minutes and i can hear this sound too like gurguling/ sizziling mix. Any idea why i hear that? could it be the fuel? or is the engine over heating. I hope its not over heating.
Old 09-19-2007 | 06:07 PM
  #95
burningpoo's Avatar
You might have to give the idle screw a little bit of a turn in or addj your LSN to help with a clean idle. Not sure if I'm right but hope it helps.
Old 09-19-2007 | 07:56 PM
  #96
I have heard sizzling and gurggling on my well NX7.6 But it runs, idles and blasts just fine!! but you might wanna try turning the lsn in(clockwise) just a touch more. It sounds like it is "loading" when at idle. But only turn in 1/8 increments. Do you have the [link=http://www.rchardware.com/]N-tune Tuning Dial[/link]. It will help emensly while tuning your engine on a daily basis..
I hope this helps
Oh and your very welcome, thats what we are here for...
Old 09-19-2007 | 08:10 PM
  #97
Alright ill try it tomorrow when i have time.
