RCU Forums - View Single Post - RX antannae routing advice
Old 09-10-2007 | 05:15 PM
osterizer
Default RE: RX antannae routing advice
I moved my straw forward a bit then attached the trailing end to the bottom of the vert fin using a length of rubber band for strain relief. On the soild fins you'd have to make a hole for it, though. Not as much straight length as I'd like, but no problems with range so far.
