RE: Problem drifting
Ya locking the front diff did not solve my problems it just caused more. With the full time 4wd its hard to break the tires loose and actually drift. I mostly drive around in circles with the wheels turned all the way unable to get a slide going. With out the locked front this thing is useless for drift and with the diff locked I can barely get a drift going. [:@] I think If I had more power I could get it to slide but the stock motor is pretty weak. Perhaps if I switch to ABS I will get less traction and be able to do it? Taping up my tires every pack is getting annoying anyways.
