RCU Forums - View Single Post - 9 Cap mix question, help
Old 09-11-2007 | 09:09 PM
JMCJET
Default RE: 9 Cap mix question, help
...... I want two mixs........
Yes. That is the answer! Use pmix6 for take off flaps, like that: mix throtle with aileron. you have five positions,so:
thr 1st pos. ------- ail % desired
thr 2nd pos ------- ail same% as 1 st pos
thr 3rd pos -------- ail same% as 1st pos
thr 4th pos -------- ail same % as 1st pos
thr 5th pos -------- ail same % as 1 st pos
Use switch c to activate the mix (center pos.). For landing flaps use pmix7, same way but with % you want. Switch c to activate the mix, but now down pos.
