RCU Forums - View Single Post - sse engine mounting
Old 09-12-2007 | 05:48 PM
troposcuba's Avatar
troposcuba
Default sse engine mounting
anyone got any pics of their engine mounting methods in SSE's? i have the ARF and am about to the point of mounting the engine. I am putting an OS .55AX in it. i was gonna wait to do it last to help get the balance right without adding any weight, but it seems that even at the lowest point i can mount it with the supplied engine mounts the carb is gonna be way above the centerline of the fuel tank. not so ideal. i could mount it sideways, and that would fix that problem, but then there is a bit of an issue with throttle linkage, not to mention cutting out the side of the plane for the head. so if any suggestions and pics are out there, thanks for the input.
