RCU Forums - View Single Post - DA-50 - understanding the Throttle
Old 09-13-2007 | 02:50 AM
Craig 01
Default RE: DA-50 - understanding the Throttle
ORIGINAL: Vahn
ORIGINAL: Craig 01
You will probably find it will perform fine .Did it run ok previously?. Carb is at idle/closed with throttle arm at angled threaded section as previously mentioned.
Yeah, it ran great actually. I flew with it three times with no problems. No hesitation or anything that I could tell. Starts great. Runs great. But, I do appreciate the inputs here.
I'll do some searches on what sort of things to look for if it's not getting enough air. If you know of any symptoms to be on the look out for, please let me know.
Vahn
Reduced top rpm would be noticed if airflow was restricted.Although i dont believe you'll have a problem as it is.
