Hi Guys,
The reason for this set up is that i am using YS 160 with hattori short muffler ... I have carefully measured the CG under the hole building process to avoid additional weight. The target for the CG have been 180-185cm , that seems a good starting point ...
The JR servos weight is 1.0 OZ each ... good performance for the job and fit perfectly without any cutouts in the stab.
The last thing i installed was the battery-pack which are a Lithium-Ion 2200 mah , weight 100 gram ... The fastener of the pack will also reinforce the horizontal web , but i would have no problem without also ...
Now the CG is 180cm without any additional weight installed ...
The rest will show when starting the new program FAI- P-09
Kjell Olav
