ORIGINAL: da Rock
Going to wide open throttle isn't bad, just getting there suddenly is.
Deflections that are too sensitive usually have too much throw as well.
Slow flight is a bunch different than flight at cruise or faster.
What he said. If you "wrap" on the throttle and pull up like the is a wall right in front of you, Your in trouble. Many tmes, the plane will roll right over on its back go in. Need to advance the throttle easy and go straight out with maybe a slight climb
