RCU Forums - View Single Post - Extreme Flight F3A Mini Build Thread
Old 09-15-2007 | 10:45 AM
  #34
3Don
Default RE: Extreme Flight F3A Mini Build Thread
ORIGINAL: twoturnspin
Hi Donatas,
Thanks for your detailed response, much appreciated, it is very comprehensive. I think you are right about the length & weight of the motor becoming an issue, I think I will need to get another motor to suit this plance. I will take your advice and go 4S aroud 2500mah, your set up sounds perfect for what I am wanting to do with this plane.
YOur video is great, thanks for sending that.
All the best, Simon
No problem Simon, some people help me with good advices that save me some time, i feel i must do same. If its possible then use Torque motor, it will fit perfectly and you get very nice performance. Im sure eveyrone in this forum agree with me that quaility of Torque motor is top notch! It run very smooth and have allot of power, and affter hard flying it come down almost cold. Also 4S 2500mah setup sound very good. CC 45a esc work perfect, i use it to. In one word great setup.
Only one thing i change is RX power, i use two separate ~400mah lypo packs with two regulators. This is just for 100% safety, also with 4S lypo esc don't have BEC.
Best luck with your Vanquish, and don't forget to use HS65mg (metal geared servo) on elevator!!!
Donatas Pauzuolis
