RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 09-15-2007 | 08:06 PM
  #2181
opjose's Avatar
opjose
Default RE: Nitro models pusher Bobcat?
ORIGINAL: marktur
OK guys, I flew it this morning with the new pipe, 30% Cool Power Heli fuel, APC 11x7 prop. All I can say is WOW! It tached at around 14,400 on the ground, and I'm sure it was another 1000 or so better in the sky. It flies the way I wanted it to now!
Yup you are running more efficiently than I am with my .76 so our speeds are somewhat comparable.... but I have more weight giving you better ( or equal ) verticals.
It's a blast to fly isn't it?
Quite impressive for a non-turbine plane.
I have my battery pack stuffed in the nose. When I adjust the G3 model the same way the G3 plane becomes much more pitch sensitive even though the C.G. is about the same.
