RCU Forums - View Single Post - Nexstar with flaps should i remove airfoil extensions
Old 09-16-2007 | 11:05 AM
hogflyer's Avatar
hogflyer
Default RE: Nexstar with flaps should i remove airfoil extensions
Did you follow the Hobbico instructions and cut the ailerons to make the flaps? If you haven't, then don't. You don't want to reduce the amount of aileron area, and flaps are not required for landing this plane. Just remove the speed brakes and wing tip droops - the plane flies much better without them.
Hogflyer
