RCU Forums - View Single Post - Nexstar with flaps should i remove airfoil extensions
Old 09-16-2007 | 11:28 AM
nothinbetr2do
Default RE: Nexstar with flaps should i remove airfoil extensions
yes take the wing droops off. also since you already cut the flaps out, you should give the ailerons alittle more throw to make up for the loss of surface area. that's what i'd do anyway
