RE: Trouble removing prop from .40 Super Tigre
make up a pair of soft jaws from a bit of cardboard or something and use a pair of molegrips to hold the little flywheel thingy (cant remember what tis called) then undo the nut whilst holding the molegrips on the flywheel, the nut should come off then spin the prop off with your finger (if its a sharp prop then wrap some masknig tape around your finger and do it
i was doing the very same thing with a 52 Surpass today :P
