RE: Trouble removing prop from .40 Super Tigre
Uh, Foamy. Unless you simply like wearing tape why don't you wrap the prop blade next time instead of your hand???
Also the prop hole size in NOT a factor in this case. It's large enough because the crank is turning easily within it. Impact wrench would probably do the job if you have one.
