RCU Forums - View Single Post - Engine causing servo glitches
Old 09-16-2007 | 09:32 PM
Truckracer
My Feedback: (19)
Default RE: Engine causing servo glitches
ORIGINAL: NLAT
ok pat i took your advice and relocated the ground to, as suggested, the fins. i started the plane and the problem is exactly as it was before.
NLAT, have you made sure your plug connector is pushed firmly onto the sparkplug. I have seen several times where guys just push it part way on, the connection to the plug is not secure and the resulting spark at the connection causes radio interference.
