RCU Forums - View Single Post - Evolution 26 Fuel line question?
Old 09-17-2007 | 04:17 AM
pe reivers
Default RE: Evolution 26 Fuel line question?
ORIGINAL: fritzdecat
<i>cut off a small ring of fuel line, and use that as a clamp by slipping it over the remaining line end</i>
easy for you to say..
Sounds like a great idea if ai can find the tubing with the right ID
You take a piece of the original fuel line, cut a 1/4"wide section off. slip that onto the beaks of a pointed plier, open the plier beaks thus stretching the ring, and slip the fuel line end in. pull out the plier. Easier done than said!
