RCU Forums - View Single Post - Engine causing servo glitches
Old 09-17-2007 | 10:01 AM
3dd's Avatar
3dd
Default RE: Engine causing servo glitches
no one has asked how much separation you have between ignition parts,batteries,switches and so on from your radio setup,i try to get all the space between them as i can.even the ignition battery can cause this if it is too close to any radio stuff.an old servo can also have a bad pot in it and be the problem
