RCU Forums - View Single Post - How does a fuel tank work? help?
Old 09-17-2007 | 01:16 PM
jetmech05
Default RE: How does a fuel tank work? help?
well don't forget there is pressure in the tank and centrifiugal force... my cluck is off the "back of the tank" but the line is too thick to allow the cluck to fall forward. I don't have a problem with flameouts either..I guess cause you don't have full power on when you're vertical down for long. if you're engine is dying when your vertical down then you have a prob with the lines or with the mixture.
