ORIGINAL: ram_z
Hi all.
I just test flew my new Integral.
My setup is:
YS 1.60 DZ with hatori short muffler
APC 18.1X10 prop
TP 1320 LI-PO and powerbox digi-switch
JR 8241 for rudder
2 X JR 3401 for elevator
2 X JR 9401 for ailerons
JR 341 for throttle
Scan select R790 is the receiver
CG is a bit forward so I will try a lighter prop like mejzlik modellbau 18X10
After 6 flights I have only one problem so far, I can not hear the horrible whistles!
Is there any way to prevent it?
Thanks in advance
Ram
Hey Ram,
I plan to use exactly the same power setup on my Integral (Powerbox Digi Switch with TP LiPo 2s 1320) How do you charge your Lipo in such case? Do you remove the canopy and disconnect the switch? I have noticed that with this battery on my older plane I had to charge every 4 flights, average consumption was 150mA per flight (8 minutes) using a YS-160DZ with ARIA mount.
I opened the box today and the plane looks very promising I don't like the classic scheme a lot but if it flies ok I don't mind, I will measure the weights of the parts tonight and I will let you know.
Regards,
Nikos
