RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 09-18-2007 | 05:46 AM
  #412
Nickolas's Avatar
Nickolas
Default RE: Composite-ARF Integral, kinda build thread
Hi Ram,
That's very light. I don't like moving the canopy and disconnecting, I think I will have to place a JR HD Switch with charge socket beteween the Digi Switch and the LiPo, the JR switch will be always on unless you want to charge or measure the voltage. Other option is to use my Duralite 2200 2s LiIon which is 50 gr heavier than the LiPo and has a separate terminal for charging so I will not have to disconnect the battery. I believe this is not as bad option considering that the HD switch will add up at least 20gr of weight.
Regarding the prop I used to fly my OTOP with an APC 16x12, now I think I am going for a 17x12 or a Mejzlik 18x10 with plastic spinner, not metal.
I really like the thick trailing edges of the plane plus the big surfaces compared to the older designs.
I will provide my weight information soon.
Nikos
