RE: receiver problem?
When you say your rerouted the wires what did you do with the receiver antenna. Did you shorten it or double it back on itself??? If so this will drastically impair the operation of the radio. The antennas on these radios are at a set length (~39") because that is where then need to be for the proper operation of the radio. But shortening it you can affect the way it operates.
Ken
